[S3m8a] Safrane 3Lv6 biturbo renovation project
S3m8a
Message par S3m8a » 30 sept. 2022, 12:13
Hello again,
as mentioned in my previous thread about the champagne V6 ph2, I was willing to get one biturbo, which finally happened :)
It is a long term project, but at least it is a complete car. The basic thing will include to make it drivable again and to be able to register the car. In the same time will be important to pass through the technical inspection, so we need to start with fluids, filter, brakes, ignition, etc.
When all these will be ready, I would like to place back the suspension pilotee because it was removed in the past and to find some original wheels becasue these burns my eyes. Of course we are far away from the ideal condition, but it will not stop me :)
oh I forgot - also it needs to be washed - that will add +5 points :up: and at least 20 kw on the power :D
Greetings from CZ
Jiri
Re: [S3m8a] Safrane 3Lv6 biturbo renovation project
Message par jpdubuc » 30 sept. 2022, 17:33
Bravo.
Tu vas avoir un gros boulot de nettoyage, y compris avec le niveau de poussières du compartiment moteur.
Tu as son PC avant, d'après le dernière photo ?
wazup 51
Message par wazup 51 » 30 sept. 2022, 20:13
Bienvenue sur le forum
S3m8a
Message par S3m8a » 30 sept. 2022, 22:27
Bravo.
Cleaning will be the smallest problem i think :) but even the cleaning will be a lot of work :)
Yes the bumper is there (broken bottom but possible to repair, missing grill but already dealing with the reproduction), indicators are there (those were removed because it was parked outside recently)
As mentioned - big project ahead :D
S3m8a
Message par S3m8a » 30 sept. 2022, 22:28
Merci beaucoup :)
GeneralChef
Message par GeneralChef » 01 oct. 2022, 01:41
Welcome Here!
Message par Palmedor » 03 oct. 2022, 12:55
Hello, gros projet !!!
Surtout garde bien les pièces spécifiques, même si non réparables, ça aide pour comparer avec celles que tu trouverais ou pour faire des reproductions
S3m8a
Message par S3m8a » 03 oct. 2022, 16:37
Thank you very much :)
With keeping and reproducing of parts i have already small experience from Avantimes :) hope the project will go smooth :)
